Hi all. It's been 11 years since you all last helped me build a machine and I was hoping you could all help me out again as I am so out of touch and my old brain is reading as much as it can but it's becoming overwhelming lol.
I don't intend to reuse any of the current system and would just like to give it to a family member as it is still going great for what they would need.
The current system is a 2500k overclocked to 4.6. Asrock Z68 Extreme4 Gen 3 with 16GB of 1333 ram, AMD 390 and a Samsung 850 pro SSD.
What I want is something that is not the best now, but still good and will have the ability to upgrade over time so it will last me far longer. I also do not require any RGB, I do not like seeing lights in my peripheral view so a closed case or the ability to turn them off.
So far I have looked at these items :
CPU : 7800X3D
MOBO : Asus ROG Strix B650E-F Gaming WIFI (Socket AM5) DDR5 ATX Motherboard
RAM : Corsair Vengeance EXPO 32GB (2X16GB) DDR5 PC5-48000C36 6000MHz Dual Channel Kit - Black
or I have seen Corsair Vengeance Black 32GB 6000MHz DDR5 Memory Kit with 30-36-36-76 CAS Latency 1.4v Voltage for the same money. Don't know if the 30 over 36 but higher voltage makes any difference.
COOLER : Thermalright Peerless Assassin 120 SE
I would need a case with good airflow, A PSU and a 2TB NVME. My daughter would give me her old 2070 GPU for now but I would like to update that in the future when I have more money to something like a 4080 or 4090.
I would also like to add in another 2-4TB NVME in the future but if I have any left over money at the moment I would get that now so suggestions are welcome. I also don't need any peripherals or windows, My monitor is still 1080P but in the long run I will get a 4K monitor to replace it.
Everything I have picked is just me looking at what sort of looks good but not crazy expensive so I'm open to people changing them except the CPU as that looks the best for gaming at the moment without spending 7950X3D money and I can swap out the CPU at the end of the AM5 cycle. Whatever motherboard and ram is picked will stay in the system for the whole duration of the machine so that needs to be able to take the last AM5 CPU released when it finally comes.
Thanks so much again for helping people out here.
CPU : 7800X3D
