Gigabyte soc force
unfortunately i forgot to delete the Asus mobo software and i cant delete it either, because it's telling me that the files are being used by another programme, it's windows 8.1..... this is because it's the same SSD from my previous rig
pc isn't starting, it's only starting up if you press the start switch again, pc also isn't turning off, when you do so the motherboard stays on and the rear fan speeds right up, but the display turns off, you can only turn it all off via the PSU switch
the bios menu is very twitchy, i cant control the mouse very well, i'm getting a message ``bios is incompatible with your hardware or incorrect bios installed``
Gigabyte website warns me about updating bios/ flash etc and i cant find the bios for it anyway.
my Asus rig was ok yesterday, the only thing that's different tonight is that if i've got a Gigabyte instead as per my sig.
is the remaining Asus folder in C Drive causing the problems or is this due to the front panel header plugs?
