^ I would go with that spec by fungus, but I would probabaly spend a little more and get the Tri-core instead of Dual-core.
Thanks guys. Can XP handle 4g fine?
yeh just noticed haj
if you spec the RAM down to 1333mhz
you can fit the tricore in the budget
cheers icey
CPU
http://www.overclockers.co.uk/showproduct.php?prodid=CP-238-AM
RAM
http://www.overclockers.co.uk/showproduct.php?prodid=MY-166-OC&groupid=701&catid=8&subcat=1387
EDIT: You could stick with the original RAM as there's only about £7 difference.
Just ordered it.
Thanks again for your help.
Just ordered it.
taking all the credit pffft![]()
I meant thanks to everyone
I got the same spec that siumatfung said but changed to the tri-core. What do you mean pics of the build? Pics of it in the stages of being built? I don't know if i could handle the pressure![]()
I'm gonna be sick giving it to my bro though, i might just shove my dell bits in his new case, he'd never know![]()
