I apologise if this is in the wrong forum area but right now I'm desperate for help, and with the OCUK helpline closed till Monday morning I didn't know what else to do.
I'm trying to get my new system up and running and I've run into a major problem - for me anyway. I've basically got everything plugged in correctly (double checked etc) but with the graphics card plugged I powered it up and everything whirred into life (red leds etc)....but no monitor display. I tried the monitor in my current pc and it worked fine so i swapped it back again. Again - nothing. So I dragged out an old graphics card and plugged that in, powered it up (whirred into life again) and still no display. So I unplugged it all and checked things out - seemed ok - and I powered it on again and this time all I get is blue led's and nothing else.
Has something gone drastically wrong here possibly? I followed the instructions carefully but now I can't seem to get anything.
Now I'm not going to give up this thing - hopefully it's something simple. But if anyone can offer any help or advice, PLEASE do so! This is a beautiful system I have here but so far I can't get it running
Here's the system specs:
Intel Core 2 Duo E6850 "LGA775 Conroe" 3.00GHz (1333FSB)
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-8500C5 1066MHz Dual Channel Kit
Sony Floppy Drive
Pioneer DVR-112DBK 18x18 DVD±RW Dual Layer ReWriter
Western Digital Raptor 74GB WD740ADFD 10,000RPM SATA 16MB Cache
Western Digital Caviar SE16 400GB 4000AAKS SATA-II 16MB Cache
Antec Nine Hundred Ultimate Gaming Case
OCZ GameXStream 700w Silent SLI Ready ATX2 Power Supply
OcUK ATI Radeon HD 2900 XT SILENT Heatpipe 1024MB GDDR4 VIVO TV-Out/Dual DVI (PCI-Express)
Zalman CNPS9700-LED Aero Flower (Socket AM2/939/754/775) CPU Cooler
Asus Striker Extreme nForce 680 (Socket 775) PCI-Express DDR2 Motherboard
EDIT*
I checked things over again and now it's powering up fine. Man - that topcase fan is HUGE!!! Anyway, the problem is that now my monitor light just remains orange - I get no display on it at all. I swapped it over to this pc (on right now) and it's working, so something is wrong with the new system setup, naturally something I'm missing. The cpu/fan were installed, albeit it was a major squeeze to do so with the metal fittings that came with it, but everything powers up ok - just no display...I am stuck...
The mobo books:
If you no not see anything with 30 seconds from the time you turned the power on, the system may have failed a power-on test. Check the jumper settings and connections or call your retailer for assistance.
Which jumper settings should I check?
Sony Floppy Drive
EDIT*
The mobo books:
