Hi, I've just installed a new Samsung EcoGreen F2 1.5TB Hard Drive SATAII 32MB which I intend to use as a data drive for streaming, however the PC won't boot with it plugged in, it just gets to the following Bios screen and stops (pressing Ctrl+S or F4 doesn't do anything):
If I plug the drive in when I'm already in Windows it works fine, I was able to format it this way, but the PC just won't boot with it plugged in!
My motherboard is an old ABIT AN7 Nforce 2, it uses the SIL 3112A SATA Raid 4.2.47 Controller. My boot drive is an old Maxtor SATA plugged into the SATA 1 socket, the new Samsung in plugged into the SATA 2 socket.
Any help would be much appreciated
Thanks
Thanks
It is much appreciated as I was close to giving up and buying an enclosure..
