PLEASE HELP -
24 Jun 2009
Hi
just changed multiplier in bios to x17 and now wont boot. Mobo says FF (nothing in handbook)... and fans going full blast!!
Any suggestions!?
Google it. You shouldn't be messing around in the BIOS if you don't know how to do that. Usually it involves shorting two pins with a jumper or removing the battery for 10 mins. Your motherboard manual should tell you too.
I know you are correct.. twas a mistake...just reading manual but nothing...
