- 1 Oct 2011
Just started the game and the temperatures went down... WHAT THE HELL?
It could be that it is not on properly, and so sometimes its okay, sometimes not. I'd suggest, if you are confident doing so, that you take the cooler off, clean it, reapply thermal paste then reattach the cooler. Also check the fan is spinning?
Maybe watch is for a bit? Weird I know, but is it struggling to start?
I mean, everything seems to be running okay (yes?) it's just this is too hot, so somethings wrong with the cooler/fan.
I'd remove the heatsink from the card. Clean off the old paste and apply new, might as well lubricate the fan as well whilst it's being taken apart.
Will do it tommorow
Okay, let us know how you get on. Hopefully that will sort it.
I just did this
Can't wait to get my EVGA GTX460 SC![]()
) When you getting it? All this may not be worth the hassle...And yeah I felt it, it's pretty hot..
Also how do I check the warranty?
