Please help!
12 Oct 2011
My rig is as described below, however I recently purchased from OCUK MSI Twin FrozR II.
Every so often my screen goes a awful purple colour and blocky like that of a ZX spectrum, I can still use ventrilo / hear sound so its not a complete lockup but I have to restart my PC.
Pic as below I was watching a youtube video when it did it, you can see it goes a weird purple colour and thats it, sorry for quality, is this likely to be my GPU? Its not overclocked from factory and runs at 28 degrees when it last crashed :(
I am using the latest nvidia beta drivers.
Thanks
http://imageshack.us/photo/my-images/826/photomfr.jpg/
Hmm, does not look good, Is there any possibility of testing in another system?
It might be worth posting in the customer section and asking for a RMA.
Jesus I had to RMA my last card to them, which I replaced with this, this one is like 2 months old!!!!
Do you think its the card?
No I dont have another system I can test it in.
Getting rather annoyed now.
Is the system spec in your sig?
Can you try the card in the 2nd slot on the motherboard, it may run at 8x but it may rule out a possible faulty PCI-e slot.
Just thinking of what to do for the best, what happened to your old card which you needed to RMA?
I know Hiper PSU were not the best and did fail, Ideally you need another system to borrow parts from to ensure nothing else is giving you problems.
Have you tried with the overclock removed and possible a fresh install of windows.
No I haven't, thing is, its really temperamental, one day I have no issues the next it does this!
If it keeps on ill format and run all at stock and go from there.
thanks for help
No probs, sorry I can't be of more help :(
I think it's one of those problems it's just the case of going through bit by bit, you almost need a complete spare pc to swop parts over and test :eek:
I wouldnt mind if it did it 24/7, then its easier to justify, its when it does it every 10 hours or so!!
