Please help
15 Aug 2011
Hi I am having issues with my new build pc,
1) my memory is 1600 but system info has it running at 800
2) as I have a fx CPU my new m-board needed flashing bios to support it, a shop did this for me but even though computer works and windows7 works, I get weird graphic problems on startup( post) I get no screen until the windows bit where the bars scroll, I also can't access bios? The button the manual says to press does nothing, I've tried DEL,f1 F10 f12 and esc no use.
3) no bios no fixing memory problem
Please help
Could you list the full specs of your system please :)
If your looking at CPU-Z at for your ram speed then you will need to double this (double data rate).
CPU AMD fx 8150
Motherboard: sabertooth 990fx
Power: corsair Hx 850
Ram: corsair vengeance 1600mhz 16gb
Graphics: xfx 6970 2gb crossfired
Case: cm storm sniper black
SSD: corsair force 3 120gb
Hd : western digital caviar black 2tb
What are you using to view the ram speed?
I know speccy will show the broken down speed, ie dual channel so 800mhz x 2 is 1600mhz.
Hmm can you not get into bios even if you keep tapping del from when you turn on?
latest version is 901 to get into the bios pres delete i would try a bios reset to see if that does anything i using the same board as you only difference is im using a phenom 2 x6 your speeds for your memory are right it is 800x2 to give you 1600. of you still cant get in the bios i would take it to the shop that flashed it for you and get them to sort it out for you
As your running crossfire, what happens if you try different ports on the GPU and try only one card if possible.
Also, how are you connecting to the monitor and what make is this?
Thanks for the info about the memory, oh well it will have to go back to the shop then, if I clear the bios, my motherboard wont recognise my CPU, do I need a phenom chip to be able to run another attempt of bios flashing. Damn
if it been updated to the latest bios it will just reset it to default settings you bulldoser will still work with no problems the only thing it will do is if you had it overclocked it will reset the setting and they will have to be redone
I am wondering if the TV does not support the BIOS resolution, is it possible to test on another monitor.
