please help
25 Jun 2009
i cant see any images in yahoo or google search, i've lost this since i ran spybot search and destroy 2.2
all i get when i click onto images is a blank page, this is in all search engines
i also lost ebay and Amazon but these have come back
thanks
firefox downloaded yesterday, i deleted the previous Firefox when this problem first happened, i've looked at windows explorer and also AVG as well, i cant see anything wrong there.
it all went wrong after using Spybot, it found loads of stuff and i deleted it all.
i used Spybot to get rid of all the Payday loan pop up adverts, these adverts are still here....
it might be worth downloading and running malwarebytes and see if it finds anything, have you deleted alll your browser history/temp files?
Check for crappy 3rd party extensions/addons in Firefox.
To properly wipe your FF.
Uninstall it, then remove this too..
%appdata%\mozilla
i cant fix it, when you delete the old firefox it asks you if you want to keep your files/ bookmarks/ passwords etc, but i dont want to loose these !
new firefox is exactly the same, loads of pop up adverts and search images all blocked
not sure what to look for, but i've tried as best i can.
1....google search images not displaying ( at top of google toolbar)
2.....grey cross appearing in Yahoo search box, search not working
3.....links not working in Google
all of this works via internet explorer, it's only Firefox that doesn't work.
all of this started since i ran search and destroy then AVG
Tools
Addons
Extensions
Check there
Backup your bookmarks then uninstall Firefox (removing the user profile)
Then install FF again. Without being at the machine, it's impossible for us to help you any more.
