Please help
3 Apr 2012
Hi all,
I've just purchased and received delivery of this system;
https://www.overclockers.co.uk/evol....6ghz-nvidia-geforce-gaming-pc-fs-145-og.html
We have an MSI gtx 970 which we purchased separately.
I did explain super clearly to the guy that took my order, that we (myself and my partner) would really appreciate it if the cables for the graphics card were already set up, although we assured me this would be the case all of the cables are tucked away behind the case.
I can't find a 6 or 8 pin power cable anywhere in the case?
Is this something that i'd need to provide separately or am i just missing it?
I bought this for my partner at christmas and you would be saving my evening of frustration with her if you could help me.
It's got a GTX 960 in there or did you ask for that to be removed?
If not then all of the cables should be plugged into that card.
That PSU definitely has the cables, although it is modular, so they will probably be in a parts box supplied? You have to just plug it into the PSU and then into the card.
we didnt get any box apart from the motherboard, and all it contains is a power plug and the hard drive cable.
edit: I asked for it to be removed because we purchased a 970 a month ago
