Please help
30 Mar 2016
Hey guys
Im looking to upgrade my pc`s mboard ram n cpu in the next month, tomo ill be buying the mboard n in 4 wks the cpu n ram. The motherboard im looking at is this one
https://www.overclockers.co.uk/giga...cket-1151-ddr4-atx-motherboard-mb-528-gi.html
This is the cpu:
https://www.overclockers.co.uk/inte...ocket-lga1151-processor-retail-cp-579-in.html
Im still undecided on the memory as yet but in youre opinion have I made a gd decision? I generally just game on my pc along with watch the odd movie. Ive got a 780ti oc graphics card 2x 256mb ssd`s which atm are running at half speed because my board only supports 3gbs sata. Ive only got a 400 budget at mo so I may only have enough to get 8gbs of ram n in coming weeks get another 8gb. So what im asking really is do you suggest a different mboard? And if you have the time mayb suggest some gd gaming ram for me. Thankyou so much for your time
What is your current Cpu m8?
Edit:I ask as its entirely possible what your upgrading from is still more than capable and you would see little difference.
On the RAM front:
Corsair Vengeance 16GB - £79.99
https://www.overclockers.co.uk/cors...hannel-kit-black-cmk16gx4m2b30-my-445-cs.html
3000MHz is a pretty good balance between cost/performance. You probably won't see much difference in performance with anything faster, unless you're benchmarking.
If SLI/Crossfire isn't necessary, then get a board like this and save yourself a few £££s.
https://www.overclockers.co.uk/asus...cket-1151-ddr4-atx-motherboard-mb-646-as.html
OCUK now have an exclusive agreement with Asus regarding RMAs. See this thread for the details:
https://forums.overclockers.co.uk/showthread.php?t=18717691
However, as MrMD says, what do you have at the moment? There's not much point in investing in new kit if what you already have is capable.
Thanks guys for replying, currently I have a i5 760 but like I said its only 3gbs for sata so ill get that improvement regardless
My basket at Overclockers UK:
Total: £357.47
(includes shipping: £10.50)
Re-use your CPU cooler (socket 1156 coolers work with 1151) or buy new.
Total: £357.47
Thanks for the bundle link, im finally getting my upgrade on my payday the 20th, was unlucky not to have full amount recently. Ive got one question, because ive waited another month, is it close to new versions of cpu coming out? if I buy now will it be old gear ina month because id prefer to wait longer if that's the case
The new Kaby Lake stuff apparently will still be socket 1151, so a BIOS flash will make the board compatible.
When is that due?
edit: found out its due sep 2016, so in that case n with what you've said ill go ahead with the skylake n jus get a better cpu if needed when released, thanks man
