- 7 May 2016
I have just installed Windows 7 today and all went well but I have a problem that keeps coming back, I will try to explain.
tried to boot up windows and instead of loading it went to the bios, I entered bios and sorted out boot order and noticed fast boot was enabled so I disabled that and saves and exits... So then windows loads and all is good.
I shut down and later I come back onto my pc and try to boot up annnnd it goes to bios, I enter bios and fast boot is enabled again? I disabled it again and saves and exits and windows works.
And just now exactly the same thing has happened, why does fast boot keep turning itself on in bios when I disable it. So confused here
