Please help
How many sata connectors does it have, are you using m2 drive
M2_10G, SATA Express, and SATA3 4/5 connectors can only be used one at a
time. The SATA3 4/5 connectors will become unavailable when an M.2 SSD is
installed in the M2_10G connector
My motherboard is the Gigabyte gaming 7 X99, It has plenty of sata connectors, 5 of my drives are connected into the sSata3 port and 1 is connected into the Sata express (you can connect 2 normal ssd's into the sata express). My pc boots every time now but the screen stays black during boot. I managed to set the bios up by using 1 card and then adding the 2nd card afterwards, if it continues to keep booting then it isn't so bad, if I ever need to get into the bios I will have to remove 1 card.
I still have the B4 code constantly and can not get into bios with 2 cards installed.
Honey I turn off fast boot and when the pc restarts it turns it back on itself every time.
