- 29 Sep 2003
- Newcastle upon Tyne
You know half of your RAM isn't being used as you're using XP.
Unless he's using 64bit XP....
Is it a SATA disk or IDE? If it is SATA then try a ne wcable and ensure that you are laoding the drivers when prompted. If it is IDE then try a new cable.
- Pea0n
you don't need to install drivers to use a SATA drive. only to use RAID.
Possibly, first time I have heard that though
- Pea0n
