Please spec me a Intel NUC or Gigabyte Brix small PC with Ram, HDD & Wins for my wife
Maybe this? Out of budget tho.
YOUR BASKET
1 x Intel NUC D34010WYK Intel Core i3 Haswell Barebones Micro PC £224.99
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02733) £73.99
1 x Kingston SSDNOW 60GB mSATA Solid State Drive (SMS200S3/60G) £42.98
1 x Kingston HyperX 2GB (2x1GB) DDR2-6400CL4 800MHz SODIMM (KHX6400S2ULK2/2G) £24
Total : £375.56 (includes shipping : £8.00).
Maybe you want something more like this?
YOUR BASKET
1 x Sapphire EDGE HD3 AMD E450 Dual Core DDR3 Mini PC £262.99
Total : £272.59 (includes shipping : £8.00).
YOUR BASKET
YOUR BASKET
I like the Nuc specs. wanted at least a i3, but it is out of budget. Need to find one cheap if I can?
Cheers matey :)
Not sure you'll find it inside 250. Windows alone will be 70 of your budget. Think you will need to look secondhand.
I got my son a nuc for christmas. Seems cheap, then add msata ssd, ram, wifi, windows. Soon jumped up to just sub £400
celeron is dual core i think cant say where it is from but they are going for under £100 which is not bad considering all it needs is a ssd and ram os is optional
This thing would be great for my wife. Just mount the nuc behind a 24" monitor and she can then surf the web. We don't have a lot of room where she wants the pc, so this would be great if I can make one cheap and is at least fast a little for web browsing?
if they are good to stream blu rays web shouldnt be a problem plus having ram should be good for having more tabs open etc
