please urgent help needed with Virus/trojan/spyware!!
15 Feb 2003
Europe
one of my flatemates, being a med student had to look up anatomy of an orgasm on the internet. Suffice to say loads of porn sites and other dodgy things came up during the search. As a result it seems her computer has been infected with spyware and a virus.
She currently has adaware (personal ed), spybot and AVG antivirus software.
I have run spybot which found 30+ incidencies of spyware, which i removed. However i then ran adaware which found the same (surely they should have been removed now.) in anycase i removed them again.
I then did a search with AVG which reported numours files to be trojans, which were removed.
However the problem still persissts. I believe that it is linked to internet explorer. I have deleted cookies, temp internet fies and clear history. I also set the homepage to something simple like google. Yet every time IE is launched AVG detects this trojan again. Also IE isn't keeping the homepage i set, once loaded it seems to change to someother page which i guess is where its downloading the virus/trojan.
I'm fast running out of ideas
How can i fix this?
Also try free online scanners, like tend and panda, just google you will find them.
Also it is important to disable system restore, many virus/spyware hide there.
Do all the scans then turn system restore back on. That should sort it mate.
good luck.
since she got the laptop through uni and never had installation disks etc.. she called them up and they said there is no way to get rid of a trojan, which has me puzzled as i'm sure i've got rid of them in the past. Are they lying?
The trojan is link to IE AVG only comes up with a warning about it when IE is launched, firefox is fine.
I feel like I should be getting some shares in Ewido but I swear by this program, it has found many a nasty that others have missed both on my system and on firends PCs that I have to sort out. www.ewido.net
/end ewido pimpage
