- 6 Feb 2004
- Wiltshire
Got a bigger photo? lol
Picture is small but it looks like a torx screw to me. Is it perfectly round or does it have small ridges? If its got the ridges it is a torx bolt and you just need to use a screwdriver with the correct size torx bit.
I find a Dremel fitted with a cutting disc does a better job than a hacksaw for cutting a slot in rounded bolts.
