Hi peeps,
I am a total n00b when it comes to PC's so I would really appreciate some help and advise.
My system specs are as follows:
AMD Athlon 64+ 3500 Newcastle s939
Asus A8V Delux mobo
Artic Cooling Freezer 64 Pro CPU Cooler
Nvidia Geforce 4 Ti4600 (128mb)
1gig Ram 4x 256 DDR
1 x 200gig maxtor hd
1x 160gig samsung hd
1x NEC 3500 DVD RW
I use my comp to play games, download stuff and to surf.
My pc is really noisey, at first I thought it was the CPU fan so I changed it but the noise remains.
Therefore I would like to change the PSU as I am 75% sure thats the culprit....
I know PSU are vital and if your PC doesnt have enough juice it could die and take several components with it.
So please can you spec me a PSU??? When suggesting if you could specifiy the name and model that would be great......
By the way I am open book so budget is open at the moment however we are all after a deal
There's no point in purchasing something I will not uliltise to its potential.....
Thanks in advance
Cheers!
Asus A8V Delux mobo
1gig Ram 4x 256 DDR
1x NEC 3500 DVD RW
Thanks in advance
Cheers!
