i presume so its not mine. replacing it is no problem which of course i will now do but the data is the issue. would it work plugging into a computer even if it's been overpowered by 19v?
I doubt it's some exotic drive that takes more than 12V power. There's likely a transformer/resistor of some sort inside to knock the electric potential down to the correct DC voltage. The drive itself is probably an off-she-shelf PATA part.
It might have protection, it might not. There's only one way to find out.
In the worst case scenario there are services you can pay that can recover data off of the platters even if the electronic guts of the drive are fried. These services are none too cheap but if this data is critical to your work you may consider it.
