Hi.
I've had a nightmare just now. I have replumbed my bath with 22mm speedfit pipe and compression fittings.
I have turned the water on and most of fittings are leaking where I used plastic. The copper fittings are fine and so are the speedfits in the system.
I did the fittings up pretty tight but was slightly wary of breaking the inserts.
So what have I done wrong ? Even though they were all tight some would spin and some came off with a yank. On inspection the olives have bitten in to the plastic a bit. The olives are brass rather than copper.
PTFE time ?
or just tighten them up even more ?
PTFE time ?
