- 12 Jan 2003
- Watford
Hi All
I have just found out that a piping joint behind the fridge is leaking. It is the one that supplies the fridge with water for ice etc etc.
I have isolated it to the ptfe junction or the valve itself - not the push fit connector.
So I need some help now as my knowledge has run out !
1 . How do I go about tightening it , or should I replace the PTFE ?
2 . Can I buy a proper replacement, which wont have PTFE tape on, and if so what do I ask for in B+Q, or does anyone have any on line links
3 . How do I replace it with regards to undoing a push fit connection ? Do I need a special tool ?
Pic below
Thanks
Mehul
Pic below
Thanks
Mehul
