- 4 Aug 2007
- Wilds of suffolk
Ive seen gate valves fitted on mains before too, really not reconmended though as they dont hold mains pressure, even new ones. Maybe the ones you made were different from the cheap crap the plumbing trade gets supplied with. Either way, they dont work.
Water meters are fitted with quarter turn ball valves above the meter, all mains water is fitted with stop tap where it enters the property. Older ones are globe valves and the newer ones are a similar design.
Compression fittings are parallel threads, BSP fittings still have tapered threads.
Thinking about it, the cheap fittings do seem to have slight tapers on the threads, I don't think they're designed to though, just cheap.
Ah cheers. Well we made everything from 1/2" maleable iron fittings to bronze fittings to 72" steel valves. It was the largest fitting and valve manufacturer in the UK (Crane fluid systems). Its no longer there, I left a fair few years ago but they were facing lots of competition from south america where only sub standard product that failed BS kept them out. I guess the south americans or likely chinese broke that barrier at some point and Cranes stopped producing in the UK.
Yeah that was my point on the gate valves, maybe in perfect situations they work but for me thay have always leaked.
