Hi. Typically in this time of lock down I have found a leaking pipe. Looking at the plasterboard under the pipe I can see its been leaking for a long time, ever since the boiler was fitted 5 years ago.
Its in an awful place. There is no room to get a compression fitting to replace the 22mm elbow.
So should I desolder it all, including the 22mm elbow and replace it all with solder ring connectors (Apart from the 22mm elbow, which will have to be one with out the solder ring)? I have found a 15x15x22 T connector, but I'll have to buy a 2 meter length of 22mm pipe to.
Maybe I should leave the 22mm elbow on and clean one end out? I'll need to buy solder since I have run out and I'm not sure I have enough gas in my blow torch, so might have to buy one as well and they are not cheap. All in all the costs are going to be quite high, maybe even more than getting a plumber out. So maybe I should get a plumber out tomorrow, but are they even doing call outs at the moment?
