Ah, two companies with different approaches to controlling traffic. Zen have no congestion on the interconnects with BT wholesale, and none on their core network. In theory, nothing on their network should reduce the performance you see.
Plusnet openly use traffic shaping. On Pro, gaming taffic is given a higher priority, though it may also still be rate limited. In theory this means gaming traffic should be treated better than other traffic types, but in a congestion situation, even some of this traffic may be chucked away. Plusnet publish the graphs of the network packet loss in their support section.
I work for one of the two companies, so I can't make an unbiased recommendation.
i have been with zen in the past and downloads was always full whack but at the time there was a 80 gb download limit i think thats been upgraded to 100 now?
so i live in a small village just over 1000 people , so how does this work , if no one else at the exchange has zen does that mean there is no contention ratio ?
I didn't ask whether they were LLU or BT wholesale at my exchange, but either way I'm hoping their service cant be any worse than BT's is.
BT Wholesale. We provision circuits on IPStream Connect, WBMC (ADSL1/ADSL2+) and FTTC/FTTP Fibre (although the latter is only in trial stages).
Doesn't sound right. Zero congestion here.I left Zen as my pings were 80 -100 on the up to 8 meg service.
Now with Xilo, same up to 8 meg service but pings are 25-30 )
Then I sincerely hope that you're better able to coax results from BT infrastructure support than I am, otherwise I've just jumped out of the frying pan and into the fire![]()
Which package?
It's dependent on many factors...however if your exchange is near capacity or your line is quite poor I would say that moving from one ISP to another on BT's network shouldn't result in a better sync rate or download speed. Pings and traffic shaping however could result in a much better experience!
The 25gb package,..with 200gb off peak use.@just over £19 a month.
Did you do anything to find the source of the congestion?
