- 20 Aug 2019
Changed my contact and been having issues with lower speeds. I should be 80/20.
I took the Plusnet Hub and installed it to allow testing to be willing and help then.
My setup before the hub was the Open Reach Modem (white box) and then an Asus RT AC68U with Asus Merlin.
The report they just sent me is the following.
KBD
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0000
Description GEA service test completed and no fault found .
Main Fault Location OK
Sync Status In Sync
Downstream Speed 38.2 Mbps
Upstream Speed 7.8 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Radio Frequency Ingress Not Detected
Repetitive Electrical Impulse Noise Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 792.3
Upstream Rate Assessment Good
Downstream Rate Assessment Very Good
Interference Pattern Not Detected
Service Impact No Impact Observed
Home Wiring Problem Not Detected
Downstream Policing Discard Rate 0.0
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-40M Downstream 5dB, Retransmission High - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2019-08-15T11:00:00
Under test using an Ethernet cable I am not even seeing 28mb.
It says my line is an estimated 792.3m in length, how true is that?
Thanks
KBD
Test Outcome Pass
Sync Status In Sync
Technology VDSL
Thanks
