Plz Help Quick!!!!!
18 Oct 2007
Manchester
Ok i just installed a Asus P5K mobo and i am in process of installing 64 bit vista premium. Problem went threw install of windows and said restarting so comp restarts and now it is stuck on screen with Asus on it and will not respond. Plz help what should i do now?:confused::confused:
try resetting the cmos on the mobo, check the manual to find out how they recommend doing it.
can you get into the bios or does it freeze before that ?
Sorted it god that was a bit butt clenching reset comp at power button and it carried on install. Time to o/c i think any tips on where to start or should i post in the other section? Thanks for help guys.
check the overclocking forum think it has a stickied guide to the basics.
any problems post in there with full system specs.
