Poached eggs on toast
Don't boil the water.
Fresh eggs is the most important. Look on youtube at a comparison video of the egg whits between fresh and old eggs, it becomes so clear why its so important.
Then i like the bring it off the boil, no stiring, basically get water as still as possible, drop egg in as fast as possible, then once it forms a white crust you can turn heat back up.
But theresc a thousand different ways and its what ever you get best results with.
Saint Delia's method is quite simple. It tends to work well because you cook the egg quite slowly, and without any stirring, so it's harder to get it wrong and end up with a rubber egg. I find it's easier to break the egg into a mug, then you've got something with a handle on it to tip the egg into the water so it doesn't expand out. The fresher the egg, the better it will hold it's shape in the water.
I swear by the clingfilm method. Works every time.
Well, the method popularised by Heston, but yes, I agree wholeheartedly.Check out Hestons method, Fantastic every time.
Depends on your criteria for a boiled egg. For me, that means it's cooked in its shell.If it is what I think it is, it's basically an boiled egg, in a bag.
