- 24 Sep 2015
i just crack them into just under boiling 1" of water in a frying pan. job done. no vinegar, no swirling etc
Ditto. Perfect poached egg every time.
8I use a small dish and cling film. Crack the egg in dish. Add salt and pepper. Tie cling film togther and drop into water. Best way I have found to do it with 0 mess or wastage.
https://www.youtube.com/shared?ci=LNkOOoABYc8
People need to read the definition of poaching. Doing film or anything else between the egg and water means your not poaching. May as well just do a boiled egg.
poachies said:Egg-Poaching Bags are a brilliant new invention. They allow water to contact the egg, without the raw egg leaking into the water.
After a few minutes your delicious poached egg slides out easily using no butter or oil. So you get proper water-poached eggs perfect first time. Every time.
Satisfied?
turn the heat down just before you put them in, stops the violent bubbling and they will be spot on
People need to read the definition of poaching. Cling film or anything else between the egg and water means your not poaching. May as well just do a boiled egg.
