- 30 Aug 2007
Hi there,
Had a hard drive fail on me
So got a new drive yesterday and have just reinstalled windows + some drivers. However, i now have a problem - The graphics performance is really poor. E.g. When using IE, loading a site (say windows update), then rescaling the window, it struggles to draw the window smoothly.
This never used to be a problem.
The machine -
Abit KV8 pro (socket 754)
Athlon 64 3500
1 gig RAM
6800
I have installed some of the via drivers, the 'VIA Hyperion Pro Driver Package', and some of the audio drivers from the same page (http://www.viaarena.com/default.aspx?PageID=2&OSID=1)
I have also installed the latest nvdia forceware drivers (169.21).
Are there any more drivers that i should have installed ?
I seem to remember having Abit µGuru drivers installed before...could that be the problem ?
Failing that, should i just uninstall these newer via drivers and just install the older drivers listed on Abit's site for my mobo ?
Thanks for the help.
The machine -
Athlon 64 3500
1 gig RAM
6800
