air con is usually a consumable or a part which isn't covered like the exhaust.
It's mad isn't it? All I can think is that there will be slightly (very slightly) reduced air flow to engine cooling but I can't see it making any difference.It's a rather contentious issue with owners too, the grills reduce the potential of damaging your radiators, but they invalidate your Porsche warrantyMany owners simply fit them when out of warranty.
You could fit and removed them come service time, but it's fiddly and if not done carefully you can scratch your intake housings and/or paintwork. There is suggestion that the dealers could then tell you've been using grills, but I haven't read any evidence of this.
When my AC stopped giving cold air, it was traced to a damaged radiator. This was replaced promptly under warranty and without discussion. Quite an expensive job at £1k+ Hence the reason I will extend my warranty when the time comes and why I returned my Zunsport grill kit unfitted.
What are these grills that you all speak of? And what are they mean to do?
https://www.zunsport.com/en/porsche-cayman-981-manualpdk-with-sensors-front-grille-set
They protect the radiators which are quite exposed to potential damage from stones. Such damage unlikely to be covered by warranty but conversely the grilles could affect airflow and void the warranty anyway - I've never seen a definitive answer on that, may depend on your Porsche dealer.
Are they popular? Iv had my car for 5 years and had no problems. Then again iv only done 20,000 miles in those 5 years.
Can you see them? Are they an eye sore?
The Boxster (986) has the DIY version with a large rectangular section purchased of grill purchased on Ebay then cut to fit the whole and zip tied behind the bumper. Needed to remove the bumper to do this, but I had to clean out the condenser/rad area anyway and inspect them for leaks etc.
FixedNo they're not similar, suggest you stop posting .
I see the words but have no idea what your talking about lol. Not very hands on myself. How old is your Boxster?
My autocorrect seemingly turned my post into a mess. Made it a bit clearer.
It's a 2993 986.
Your autocorrect hates you.
Christ on a bike, wtf is this Huawweeiii thing doing
Need to re-read everything.
Is it translated from chineseChrist on a bike, wtf is this Huawweeiii thing doing
Is it translated from chinese.
