Port scanners
7 Mar 2005
Wolverhampton
I have a friend asking me for help. Basically something is blocking her pc from accessing a game.
I've downloaded the same file she has, i can connect but hers is blocked. Ive took off all the firewalls, the only thing left is port forward.
I'm remote accessing her pc, is there a good program i can run that will tell me what port the game is trying to access? So i can then go and open it in her router settings.
Cheers.
Well i took out the router, and its still blocked.
Any idears, ive turned off vista's inbuilt firewall, theres no other virus/firewall programs installed.
If the game icon is on the desktop right click and Run as admin (or something like that, been a while since I touched Vista!)
Otherwise use file manager to find the game executable and do the above.
M.
LegendOfMir.
The problem was the game wouldn't connect to the auto patcher, so wasnt updating, rendering it unplayable.
Seems to be fixed now tho :eek:
