Portable HDD 250gb to 320gb...
7 Jan 2003
Gold Coast, Australia
I want to get a 250gb to 320gb portable hard drive for my dad it must not be any more than £60 which ones have you guys had experiances with and would you recomend?
Thanks
You're pretty limited really.
On OCUK, there's only 2 for less than £60, but there's a couple more for up to £65.
http://www.overclockers.co.uk/showproduct.php?prodid=HD-052-FC
http://www.overclockers.co.uk/showproduct.php?prodid=HD-165-MD
http://www.overclockers.co.uk/showproduct.php?prodid=HD-186-SE
http://www.overclockers.co.uk/showproduct.php?prodid=HD-193-SE
From other sites theres the (can't link):
Toshiba 250GB
Western Digital My Passport 250GB
Buffalo Ministation Lite 320GB
All for less than £60.
I don't know about performance though. I'd imagine the Seagate and Western Digital drives would be good, but it's hard to tell without knowing what specific drives each one has.
Alternatively you could try buying an enclosure and a 2.5" drive, but that'd work out a little more expensive.
Thanks for that mate apreciate it!!
Hopefully someone will be able to review or give some advice on some drives they have some experiances with.
