I'm thinking of going with the above build for my gaming rig, as I have not built one before I'm looking to you guys for advice
I'm on a £650 budget for the time being, and looking to run Battlefield 3 at around med-high settings at a comfortable FPS.
My major concern is the case, I maybe looking to crossfire the 6870 a few months after purchasing this, would the case provide me any space problems, I've read the reviews which seem to say it is quite a spacious case.
I know I probably would need to upgrade the PSU if I was to Crossfire aswell.
Does everything that I have added to that list look compatible, and fit well within the case?
Thanks in advance
