Possible dead PSU/Mobo... help please!
  • Thread starter Thread starter Ham
  • Start date Start date
Ham
Ham
11 Mar 2005
Somerset
Hello
Went to turn my PC on today, pushed the power button and nothing (no fans/post/totally dead). Did the usual checks (kettle lead, PSU switched on and such) before opening up the case. The Mobo had a couple lights-on including reset CMOS, power and reset illuminated buttons. I tried the mobo power button and reset the CMOS but still nothing.
I tried removing RAM/HDD/Graphics card... I've now disconnected everything from the mobo except the CPU/fan and power connectors though still nothing has changed.
The system was working perfectly fine yesterday. I was gaming in the day and browsing for a couple hours last night, shut down as normal before bed. Any suggestions of anything else i can try before i start spending money? Guessing it's either the PSU or motherboard though any thoughts would be appreciated.
Spec -
Asus Maximus Formula
Q8400 (mild OC to 3.2 @ just over stock volts)
2 x 2GB Hyperx
Corsair HX620
Cheers
Ham
You could try the PSU by linking pins 13 & 14 on the main ATX connector (not counting the extra 4 pins) with a paper clip and see if the PSU starts, I would just have a fan plugged in for a little load only.
this, there are loads of guides on google or youtube.
or if you have a multimeter, you can use that also
Thanks for the suggestions. I gave the cmos an hour+ to sort itself out and still nothing. I also tried the paperclip trick whilst leaving a couple case fans + the optical drive plugged in and there was still no life at all.
I popped round to my Dad's who gave me a voltmeter to try. I gave it a go though seemed to be getting some strange readings; some pins would give a steady reading and others would continually rise, some to 1000+ until the meter beeped at me. Not sure if it was the right tool for the job and i'm not exactly savvy when it comes to electrics though the readings didn't fill me with confidence.
Looks like it's time for a new one.
Just realised the Corsair unit has a 5-year warranty. I've now contacted Corsair support for an RMA (they suggested the paperclip test in their support section).
