Hi Guys,
Before I strip my system down to ascertain whether my Titan X is dead can you suggest any other things to try?
My set up is 3 titan x with dual loop cooling. I have Rampage V Extreme and this board has on board PCI slot status. The first three PCI slots are where the cards are installed. 1 & 3 are lit up but 2 is not.
I have re installed drivers.
I have changed the power cables to check it wasn't them.
Anything else worth trying before I drain it all down and try it in another slot?
Not sure if linked but I had a faulty M2 SM951 drive that I had to take out and then I had to reinstall windows. I think the second card stopped working at that point but can't be sure.
Serves me right! To be honest I was about to start stripping it all down to move into a CaseLabs SM8 anyway so probably not end of the world.
