Possible faulty PSU? Keeps restarting
9 Mar 2006
London
So I'm having issues with my system shutting down was more random now it's happening every 1-10 minutes sometimes I'm lucky and getting a couple hours use.
Sometimes it will completely shut down and not switch back on unless I unplug it from the back and plug back in.
The hard drive is new and recently formated and a new install.
Checked all cables all seems to be in order checked the PSU plug and switched for a different one.
I thought maybe this is a faulty psu but was advised in store that it could be the motherboard before paying out for a new power supply and might have the same issue and get it diagnosed.
What's your opinion?
Never had to deal with a psu before they just always ran perfect
Could be the CPU overheating if you are putting it under load, perhaps the PSU itself is shutting down if you are putting your PC under load.
It would help others here & myself if you posted the make & model of your PSU, then suggestions can be made to resolve your problem.
Listing your spec along with the make and model of PSU would help us to help you. Check your temps as well. If you have a RTX3000 series gpu it could be transient spikes causing it but without knowing any of your pc's details it could be anything.
Thanks for all the reply.
The specs are as follows its a bit outdated but for what I use it for has been working spot on for a long time was thinking on a new build next year.
PSU: CORSAIR TX 750
Motherboard: Gigabyte GA-Z77X-UD3H
RAM: Corsair XMS3 X4 8GB
GFX: EVGA GTX 1070
This can happen after being switched off for all night so don't think will be overheating issues have been when possible checking temps with speed fan everything seems stable temp wise
