Possible gaming sff.
30 Nov 2008
Brecon
Hey guys,
Im planing to build a new gaming/Linux pc/box to replace my ancient p4 pc.
Due to the relative cramp area on and under my desk I'm planning on a a small form factor pc.
I'm hopefully looking (if i get this quarter bonus) a i7 based kit:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-059-DF&groupid=701&catid=5&subcat=1283
board in a
http://www.overclockers.co.uk/showproduct.php?prodid=CA-154-LL&groupid=701&catid=7&subcat=187
case,
The only two issues are what gpus can i fit in said case and where can i get a cpu cooler that will fit in the case? Or wouldit be better to set up a water cooling system?
Thanks in advance for the help.
Any GPU will go, although it'll require mor epatience if it's bigger as it's a small case!
CPU Cooler - go for the Scythe Mini-Ninja. It fits and cools very well. Better than anything for the size.
Thanks, i was having nightmares of trying to sort out water cooling.
That cooler won't cool an i7 (or even fit on a LGA1366) as they're very hot, also having a small case too won't be brilliant helping cool an i7 either. As for the case I have seen 4870 Xfire and a 4870X2 so quite a lot of cards fit.
So maybe go for a quad core? it would be a lot cheaper i suppose.
If you are going to watercool it'll be fine, but with a hot GPU and an i7 in a SFF case it'll be pretty dam hot. A 775 quad will be a HUGE step up from a P4 anyway so I'd go we that route, and as you said cheaper too :)
P4 extreme 3.6ghz of single core POWER!!!
I don't think i have enough experience to comfortable build a water cooled pc.
Is there a reason for the overpriced ram? Just whack in a 4GB set of Kingston Hyper X (either 800/1066Mhz you won't need more) for about £5 more doesn't matter if you don't have a 64bit OS either.
Is there a reason for the overpriced ram? Just whack in a set of Kingston Hyper X (either 800/1066Mhz you won't need more) for about £5 more doesn't matter if you don't have a 64bit OS either.
Think would be better to get 4GB of a cheaper set of memory.
That or the stock cooler, I'm unaware of any other small coolers for it.
I just don't understand. Surely the Mini-Ninja is the only air cooler that stands a chance of cooling an i7?
Unless stock coolers have improved a lot... :p
The mini-ninja doesn't support socket LGA1366 only LGA775, i7 is socket LGA1366 and stuff like the Q6600/Q9550/E8500 etc are all LGA775.
