Greetings all,
I'm in the process of building my daughters a gaming PC for Christmas. I've just purchased a 2nd hand RX580 GPU and i've put just put it in my own fully built pc which works perfectly however after installing the drivers and trying to run time spy to benchmark it - the displays both just stopped working and i had to hard reset the PC. I've checked that the drivers are up to date as shown below.
I'm currently using a 850W ASUS ROG STRIX 850G White Edition, Full Modular, 80PLUS Gold PSU so it shouldn't be an insufficient power issue - it also works fine with my 3060Ti card.
Anyone else had this or knows what's going on? I suspect the GPU is naffed but i want to see what you guys think.
Thanks
Edit: Just logged in World of Warcraft on it and in 10 seconds the temp went from 40 degrees to 75 degrees and the fans started screaming. This is with an open side panel also.
Picture of CPUID HWM
Thanks
