Possible HTPC/Home Server Builds - Thoughts?
1 Aug 2011
Been thinking about building a HTPC/home server for a while and have started to throw together a couple of builds. However, I'm not sure how much better one would be than the other. I don't want to spend more money than need be when what I want them to do is to tick the following boxes:
  • Play HD video and music straight from the HDD and stream it over the network
  • Stream video directly from the likes of iPlayer, YouTube, and so on...
  • Always on server so I can store files I want to access when I'm not at home or stream video/music
  • Rip DVD/Bluray (willing to forfeit this)
I've come up with two builds so far, one significantly more costly than the other. Neither include optical drives or PSU as I'll figure those out as soon as I know the rest and I may be willing to forfeit the optical drive in the budget build for a second HDD. Are there things in the list above that the budget build wouldn't be able to do that the higher end one would?
HIGHER END BUILD - Approx. £575 w/o PSU or Optical Drive
  • Zotac Z68ITX-A-E Intel Z68 (Socket 1155) DDR3 Motherboard
  • Intel Core i5 2500K 3.3 GHz
  • 2TB Western Digital WD20EARX 3.5" (To add more later on)
  • Corsair Vengeance 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit
  • Lian Li PC-Q11B
BUDGET BUILD END - Approx. £290 w/o PSU or Optical Drive
  • ZOTAC FUSION350-A-E OR Asus E35M1-I DELUXE AMD
  • (2x2GB) PC3-8500 DDR3-1066MHz
  • Lian Li PC-Q07B
Thanks for any help.
Also thinking about an alternative build for approximately £330
  • Asus P8H67-I
  • Intel Core i3 2100 3.1GHz
  • 8GB (2x4GB) Corsair DDR3 XMS3, PC3-10600 (1333)
  • Lian Li PC-Q07B
I would say the third option is probably the best one of that lot, but if it was me I would stick with 4GB RAM because you just dont need more for the things your outlining. I would go with the Q11B though, it would allow you more room for expanding the hard drive base later on and also it will be better ventilated if its going to be on all the time that will be important. I would also consider a decent silent CPU cooler, something by Scythe maybe.
Hawker
Thanks hawker. I'm thinking about sticking a GPU on there and running a few games on the thing eventually, so I'm planning ahead with the RAM. Going to go with the PC-Q08B in the end. The 6 HDD bays made it a bit too tempting to ignore (even if it is ugly).
While I'll agree that the Black Q08 is maybe a little plain, its far from ugly.
The Red model however is beautiful :)
Ah my mistake, I thought the q11 was the q08, good choice well made :) TBH gaming still wont need 8GB RAM, but with it being so cheap atm why not. Enjoy the build.
Hawker
Ended up with a few changes.
For the case I've decided I'm probably going to go for the Lian Li PC-QO8B. Want something with at least 4 3.5" HDD bays and that seems to be hard to find. This was the best I could see. The 2 3.5" and 2 2.5" seems a little too few with the PC-Q11B. 2.5" drives seem a bit on the pricey side anyway and don't offer a lot of storage. Any other suggestions on a case? I'd love to find a decent case with 4 bays.
Narrowed the motherboard down to 3 options - most likely going for the Asus or the Zotac. The Asus if I can find a case with 4 3.5" HDD bays and the Zotac if I can't. May as well have the option of using all 6 bays on the Q08B.
Gigabyte GA-H67N-USB3-B3 - No WLAN? Don't want to take up the PCI slot with a WLAN card and only 4 SATA points.
Asus P8H67-I Deluxe - SO-DIMM memory and only 4 SATA points. Any disadvantage to using SO-DIMM?
Zotac H67ITX-C-E - 6 SATA points, but have read it can be a bit power hungry and little fan control?
All seem to offer the same Wake On LAN support.
Going to stick on an AMD 6670 or 6750 for gaming and I've also heard that the i3 has issues with 24p video. Also means I'm not interested in the Z68 chipset as I'm not going to use the hybrid graphics or likely to use the SSD cache. For the CPU I'm almost certainly going for the i3 2100 3.1GHz since I'm putting the GPU on there and there doesn't seem to be any difference between that and the 2105.
Zotac H67ITX-C-E
Intel i3 2100 3.1GHz
4GB 1333MHz DDR3
AMD 6670
Lian Li PC-Q08B
PSU?
That's how its looking at the moment - approx £450 w/o psu
Asus E35M1-I DELUXE E-350
4 GB DDR3
Lian Li PC-Q08B
is coming in at approx. £320 without PSU
can I really justify the price of the i3 build for what I want to do (bearing in mind it may eventually have 5 HDD on there and be function as a server and HTPC at the same time)?
Just built one of these:
Spec:
CPU: ATHLON II X4 600E 2.2GHZ SKT AM3 L2 2MB 45W PIB - £101
MB: Saphire AM3 AMD AMD785G DDR3 mITX - £94.83
Mem: Corsair Value 8GB (2 x 4GB) DDR3 1333MHz DIMM 240-pin CL9 - £54.99
Case: Thermaltake Element Q Black with 200W PSU - £47.97
SSD: Corsair Nova Series 2 60GB SSD - £77.98
Total Inc VAT & Del: £376.77
think i'm going to go with the zotac and i3 build
still need a psu. i'm guessing 300W would be enough. maybe 250W at a push? any recommendations for this case that aren't going to get in the way of the HDD bays?
also can anyone recommend a good, silent 100mm cpu fan?
Zotac has 2 pwm fan points, maybe that enough for a mini case ?
I have a mini Shuriken for my 2600K, but the stock cooler on my 2100T is fine and pretty quiet.
I think the seperate option gives much more longevity andd future upgrade options
I am tempted to try the Be Quiet BN134 PSU. 35OW maybe be more than needed but it will be quiet
If I use a 350W PSU instead of a 250W PSU then that isn't going to draw any more power with that build, is it? It just means that its capable of drawing that power if it needed to?
You're right, the efficiency of the PSU is more important than the rating to save electric.
If the Scythe Shuriken SCSK-1100 is compatible with 1156, its also compatible with 1155, yes?
yep, the pins just slide to fit a range of mobos, it also has push pins, they are easier on the Zotac 68 as backplates genreally hit components on the underside of the board
Get a HP Microserver, install an ATI card and W7.
Exactly what I have done and I do all of that with it.
Total cost was:
HP Microserver (after cashback) £110
ATI low profile gfx card (4550 I think) - £28
4 GB ram - £30
And then whatever disks you need.
Will the BN134 fit into the PC-Q08? It wants a full ATX PSU, doesn't it?
Q08 will take a full ATX psu so will fit the BN134 no problem.
The BN134 is basicly a standard ATX psu chopped in half.
