Possible HTPC upgrade
10 May 2004
Middlesex
Hey guys,
My parents have an old PC which they would like upgraded to a HTPC *if possible*. I've got a couple of questions.
This is basically all I will be carrying over:
Pentium E2200
Acer - F672cr-R01-A4 mobo
OCZ Vertex 2
I guess my first questions is, on win 8 will this be ok for 1080p video (I will be buying a gfx card)?
This is the case they would like:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-163-SV
I'm finding it very difficult to find documentation on the motherboard, I think it should fit in the case but could anyone confirm?
The other problem I have is there are only 2 sata ports. I will have a vertex 2 and a storage drive but they will also need a DVDRW in there. I have seen sata>IDE converters cheap on the bay. Do these work?
Right, if everything there checks out and will work together can you guys help me spec the rest up please?
I'll basically need everything else to go along with the above (excluding keyboard, mouse, speakers). They will need a GFX card that fits in that case which has an HDMI out and a wifi card or USB wifi dongle and it will need to be as quiet as possible at about 7 feet. It's currently using the intel CPU cooler (will this be quiet enough?)
Budget is as cheap as possible really.
I know it's quite a lot to ask but any help will be much appreciated. :)
Thanks a lot for that. I have been thinking it may be better to go down the Trinity route but that puts an extra £130ish onto the budget which could be spent on the storage drive and Media keyboard etc.
The case I linked above supports standard ATX PSUs.
The other option as far as only having 2 ports is concerned I suppose is to just go for the HDD and leave the SSD out. If it's left in hibernate the whole time I guess boot up time may not be much of an issue.
- Limitation of CPU cooler: 70mm
- Limitation of PSU: 140mm
- Dimensions: 440 mm (W) x 105 mm (H) x 340 mm (D)
Many PSUs you will see are 150mm. So you need to be careful. That's why I used the thermaltake case with a picoPSU supplied ;)
I see, thank you. :)
I take it the mobo I already have wouldn't fit in that case?
If all is ok I am looking at ordering this today:
YOUR BASKET
1 x Toshiba (7K1000.D) 1TB SATA 6GB/s 32MB Cache - OEM (DT01ACA100) £54.98
1 x Silverstone Milo ML03 HTPC Case - Black (SST-ML03B) £52.99
1 x Seasonic S12II 380W '80 Plus Bronze' Power Supply £42.98
1 x Xebec HTPC/Console Handheld Keyboard £34.99
1 x Asus HD 5450 SILENT 512MB GDDR3 PCI-Express Low Profile Graphics Card £22.99
1 x Samsung SH-S222BB/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £13.99
1 x TP-Link 300Mbps Wireless-N USB Adapter (TL-WN821N) £12.98
Total : £249.42 (includes shipping : £11.25).
I believe the size of the mobo is 224mmx221mm (I have found some documentation on the desktop it is coming out of, it states that is the size of the micro atx 'PCB'. I assume they are referring to the mobo).
Will that fit in the case?
YOUR BASKET
It`s mATX, so should be all right. They come in different sizes, but as far as I know the screw holes are all spaced the same. I have a board smaller than yours and it fits in a mATX case.
Yes the case takes mATX. Look at THIS HDD which has double the storage, you were happy to pay close to that in an earlier spec
Yes, I know. They are still weighing up the extra cost for the 2tb.
They are basically going to be using it for netflix and the odd 1080p film which will be deleted after it's been watched. I doubt they will benefit from the extra storage.
Thanks a lot for all your help guys!
I'm using a first gen llano system in a Milo ML03 like you linked to in your first post.
Particularly like the fact it takes an ATX PSU - just be careful to get a PSU and optical drive shallow enough to fit without squashing one another. I didn't have to worry about this as I don't use an optical drive. Is used as a TV and online on-demand box.
Cooling is good and with a raft of ultra slow rotating 80mm fans a scythe shuriken cooler and the fanless PSU it's nearly silent.
System specs:
A6-3500 tricore APU
Gigabyte A75 matx mobo
Scythe Shuriken low profile CPU cooler
4GB 1333MHz DDR3
Silverstone ML03 case
550w Yesico ATX PSU (Fanless design)
50GB Vertex 2 SSD
1000GB 3.5" mechanical drive
DVB-S2 and DVB-T TV cards
USB PICO WiFi Wireless N adapter
