- 29 Oct 2002
Hi folks,
I've recently acquired an ITX-ish sized PC that I was thinking about re-purposing to a NAS box. The specs are as follows:
Do you think this would be good enough to run a simple FreeNAS unit, or would I be needing something better? I know I'd need to probably add USB3.1 which I can do easily (electronics engineer/cable magician) but other than this do you think it'd be capable??
Cheers for any advice!!
- Processor: AMD Athlon X2 7450 2.40GHz
- Memory: 4GB RAM (Not sure if I'd need to up this, if possible...)
- Hard Drive: none (I have several options available)
- Optical Drive: none (as above)
- Operating System: Microsoft Windows Vista Home Premium 64 bit
- User Interface: 2 USB, Headphone, Microphone,HDMI, VGA
- Graphics Controller: nVidia Geforce 8200, HDMI port on-board
