I'm going to be getting a new PC in the new year. It's going to be a purely gaming & browsing PC, I know you can't future proof to much, but I'd like to get as much useful life out of it as possible, I'm still running an I7 860 that I got in 2009. to give an example of how much I want to squeeze out of it.I'll be asking OcUK to build & overclock it for me. so that'll put the price up, but I'm happy with that.
I've got a KFA2 GTX 970 OC Silent "Infin8 Black Edition" that I'm going to use until Big Pascal comes out & I'll add that to the loop or setup it's own loop if there's space. I've also got Windows 7 Professional CD that I can copy onto a USB stick install that then upgrade to Windows 10.
Any opinions would be appreciated.
My basket at Overclockers UK:
Total: £1,600.23
Thanks
- 1 x Kingston Predator 16GB (4x4GB) DDR4 PC4-24000C15 3000MHz Quad Channel Kit - Black (HX430C15PB2K4/16)= £119.99
- 1 x EVGA SuperNova G1 1000W '80 Plus Gold' Modular Power Supply= £129.95
- 1 x Samsung 1.0TB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E1T0B/EU)= £259.99
- 1 x Lian Li PC-D600WB Big-Tower - Black= £279.95
- 1 x OcUK Tech Labs - V12 Watercooling Kit 360 = £262.39
- CPU Block:EK Water Blocks EK-Supremacy EVO - Acetal+Nickel (Original CSQ)
- Tubing Colourrimochill Primoflex Advanced Tubing 16/11 - Clear
- Coolant Choice:Mayhems Pastel - UV White Coolant 1L
- Radiator:EK Water Blocks EK-CoolStream PE 360 (Triple)
- Pump & Reservoir Option:XSPC D5 Photon 270 Reservoir/Pump Combo
- 1 x NZXT Hue+ RGB Dual Channel LED Controller - Black= £47.99
- 1 x NZXT Grid +, 6-pin Fan Distributor With CAM control software= £19.99
- 1 x MSI X99A SLI Plus Intel X99 (Socket 2011) DDR4 ATX Motherboard= £179.99
- 1 x Intel i7-5820K 3.30GHz (Haswell-E) Socket LGA2011-V3 Processor - OEM (CM8064801548435)= £299.99
Total: £1,600.23
Thanks
