Possible project: tailgater deterrent
If you are deadly serious about this :D:D, just get the sign and switch it on when you start getting bothered. Job done.
hahahahahahah :D:D:D:D:D:D:D just laughing about this thread. what an idea..............
yeah, good point.
If you want to go to this length, why just make a james bond car with oil slicks, spikes and napalm. Jobs a good 'un
Personally, I think you'd be better off with a smoke screen. Plumb in a washer bottle into the exhaust manifold, filled with snotty old engine oil and it'll white the entire road out at the press of a button and cover the car behind in stinky oily crap.
Why not hook up the sensor to a oil slick generator underneath the car? That would be dangerous yet awesome. Or maybe some rearward-facing HID Main Beams?
Or how about this? Also and HID, but 18,000W instead of a paltry 35W ;)
May need an uprated alternator however! :eek:
Without telepathic mind control, I don't see how this is possible.
Not really you have a few options open to you.
1) Leave a bigger gap infront so you can allow for his braking time
2) Rest foot on the brake pedal every now and again
3) Slow down 5mph then speed up 5mph
Most people soon get the idea, if the person doesn't well its no big deal, just use option 1, afterall its a safety problem and this solves most of the issue.
If people struggle to work out why this helps, it enables you to brake much more gradually and reduce the chance of the car behind hitting you.
Hit the brakes so hard that they crash into you, get out, beat them to death with a wheel brace, and continue your journey. Buy a Volvo so the damage is minimal. Or just ignore them. :p
Seeing as it's near Hallowe'en, do this:
Get a scary mask and put it on the back of your head before setting out.
If you get a tailgater, lean your head between the front seats and if he can see you, he'll **** himself. Or roll the window down and lean your head out.
I'm convinced that some tail-gaters don't even realise that their doing it so no matter what you do they'll always be close behind you.
Unscrew your exhaust so it looks like it's going to fall off at any moment, they will then keep their distance.
