Possible Psu Problem
You need to use CPU voltage offset,and the right loadline calibration setting
Idk how your clocked atm,fixed or offset
But if it uses more voltage than you want/need then use less offset
I think it is on Auto atm. I`ll have a go at lowering it tomorrow. Right, that`s me done, I`m off to bed, will update later tomorrow. And thanks again, guys.
you can try maybe high llc and +0.020 cpu offset and see what the load cpu voltage is in cpu-z while stressed,then adjust the offset to suit
Glad to see that you got it sorted mate, look forward to seeing your clocking results.:)
Cheers buddy, it was a bit of relief to say the least. :D
Did`nt get a chance to do anything yesterday, but hopefully will be able to get stuck in at the weekend.
But I will continue this in the other thread. I just want to get the Vcore down as low as possible. Also, hot happy with the ram voltages, I have it set at 1.65v but it runs at about 1.663v, which it`s never done before.
Managed to sort out the Skt 775 mobo and Cpu issue. Tried it with an E5200 and it worked first time. So now have the Q6600 up and running. But I need to get a Psu with an 8 pin Cpu connector, before I can OC it, but not in any hurry.
