Reviews will show if that's trueYou can be sure reviewers will test it's limits, just like they did with the 970
Originally Posted by SimBy View Post
Reviews will show if that's true You can be sure reviewers will test it's limits, just like they did with the 970
Fixed![]()
Most 'reviewers' = Benchmark monkeys. Any dumbass can do that...
4GB HBM does not = 4GB GDDR5
It has up to 4 times the bandwidth, is up to 50% more efficient for power and more importantly increases the amount of power available for the GPU.
Yes but 4GB of textures is still 4GB of textures.
Or put it this way, a pint of water is a pint of water, whether it is in a bottle or a bucket, or even a super high pressure hose system, you may be able to empty some Quicker than others but if all three only hold 1 pint then you cannot squeeze more than that into it. all three will still be filled by the same tap as well, in this case the HDD/system ram.
Trains A and B are traveling in the same direction on parallel tracks. Train A is traveling at 60 mph and train B is traveling at 70 mph. Train A passesa station at 12:20 P.M. If train B passes the same station at 12:32 P.M., at what time will train B catch up to train A?"
someone ****ing shoot me![]()
train A goes up my Ass, it's painfull but does anyone give two ****s![]()
I know how it depends on your total amount of VRAM and the "extra" frame buffer if you have it available (I have used a vast array of GPUs) but let's not forget most people wanting to drive 1440p or 4K with good FPS (60FPS) are looking at this card or (the small number) of 1080p user that are looking for 120FPS+ or/and futureproofing for newer games.
Adding a second card is going to allow you to have that FPS (60+) on the highest settings with MSAA so why should you need to drop something due to a VRAM bottleneck ? (most SLI/CFX rigs are the medium to high end tier not the low end)
When you shell out cash on a new toy ($XXX if not more) on the highest end I doubt you want to turn down settings.
3GB is borderline up until 1440p (for newer titles) you are going to have to lower quite a few details.
4GB is ok for 1440p (for most games) some you are going to have to sacrifice a detail or two.
4GB is ok in some scenarios for 4K but don't be surprised if you hit that limit when going over medium-high settings (even without AA) in AAA titles.
I also want to add something, the difference moving from SLI GTX970 and CFX R9-290s 4GB to 12GB VRAM TX (single and SLI) has a lot to do with the frame buffer.
More = less swaps = smoother gaming experience
Why did you bother writing any of this? 1) If you're going CF, all DX12 / Vulkan games should pool memory. Therefore 2x Fury = 8GB. 2) HBM can swap larger files and more of them than GDDR5, and at lower latency, and DX12 / Vulkan can do the same, plus tiled resources. When the option is to go 4GB HBM or GDDR5 (and much slower GPU and less bandwidth), the answer is pretty damned obvious.
Why did you bother writing any of this? 1) If you're going CF, all DX12 / Vulkan games should pool memory. Therefore 2x Fury = 8GB. 2) HBM can swap larger files and more of them than GDDR5, and at lower latency, and DX12 / Vulkan can do the same, plus tiled resources. When the option is to go 4GB HBM or GDDR5 (and much slower GPU and less bandwidth), the answer is pretty damned obvious ... plus they make their transition to interposer, new memory, and new memory controller on a familiar and reliable process - they don't have THAT much to do for Arctic Islands ... NVIDIA have their work cut out with everything new on an unfamiliar process, and coming much later to the stacked memory (and certainly HBM) game.
First of dx12/vulcan, Can pool memory but that doesnt mean that all if any games will do so. IIRC was also a feature of mantle yet wasnt used.
Second point it wont affect older games of which most of us have so pooling is imo irrelevant atm as its a possible feature that hasnt been used and wont work for non dx12/vulcan stuff
Hopefully HBM will help with the Vram issues but atm we dont know
