Possible reasons for crashing?
6 Jun 2009
Hi all, a friend pointed me to this site, so I hope you guys can help! I bought a new assembled system, and it keeps crashing on Windows 7, both 32 and 64 bit. I checked inside the case, and while all wires are connected and everything seems fine, one thing bothers me: It's a core i7 860 processor on a P55 pro mobo, and I remember reading the i7 need 3 sticks of ram. This PC has that, but having 3 sticks or ram means there's one open slot. Shouldn't slots be filled per two, ie either 2 or 4 sticks? Could this be the reason for the constant crashing? The PC just freezes completely, no BSOD or anything. I can get some work done for an hour or so before I have to hit the reset button on the PC.
i7 uses triple channel ram, hence the 3 sticks, you dont need 3 but it runs best with 3 so all channels are being optimsed.
Take out 2 sticks and try with one stick and rotate which slot it's in.
Did you build it youself? is the heatsink / fan attached properly?
See sticky for build help, might help you diagnose where the error lies.
Try one stick at a time run memtest in case you have a faulty one, make sure you have the right timings and voltage for your memory.
Thanks for the tips guys, I've done some memory tests and ended up booting up hardware tests for the HDD and CPU as well. No luck there, so did a couple more fresh installs, and it turns out ATI Catalyst was to blame (at least until the next crash which will rule out that possibility).
