Possible replacement cables for Goldring NS1000
15 Jan 2006
Derbyshire
Being as the ANC7 and ANC7b are also based on a Phitek OEM model with detatchable cable I thought these might come in handy, particularly for those of you that got the recent version with the 1m cable (rather than the original 1.8m).
Looks like they should probably fit the NS1000s:
1m: http://www.audiotechnicashop.com/index.php?route=product/product&product_id=252
1.6m: http://www.audiotechnicashop.com/index.php?route=product/product&product_id=253
Anyone fancy giving it a try?
Just do my drill mod it takes 15 mins or less and someone buy that belkin iphone adapter for 99p I think it probably fits I made the mistake of not getting that and getting the exspect iphone adapter.I did a real basic job as I have had my ns1000 for quite a while I used the first rusty old thick drill bit to hand and didn't take any great care just slowly rub in an arc motion along the side of the drill bit at the bottom part of the hole.Could make it quite tidy if you take your time and use a small drill bit and have a rounded file or knife sharpener.
I swear this will fit without any modding (not sure) can get one for 99p on that auction site worth a punt though.
