Possible to make the 360 wireless...
11 Jul 2004
Neptune
...without having to spend £60 on the official adapter?
Is there another, cheaper, way of doing it?
Edit: ideally without having to bridge my connection from another PC/Mac.
Edit 2: ooh, i do have a spare Airport Express. Would that be usable?
You have a Mac don't you?
You can plug the xbox into the ethernet of your Mac and set the mac so that it shares the connection that you get from wireless to the xbox.
There is some tutorials on the net.
http://www.joystiq.com/2006/07/17/how-to-share-your-macs-internet-connection-with-your-xbox/
I do indeed. Might give that a go.
Nothing I can do with the Airport Express? Extend the wireless network and connect it to the 360 via ethernet? That's what I was hoping.
I think I mentioned this the other day in another thread. A wireless bridge is the easiest way, but decent ones cost about 80% the value of the official wifi adaptor. It is a crappy solution anyway as you still need a mains outlet to plug the device into (obviously the 360 adaptor is USB host powered).
Some people suggest buying a cheap router/access point and using that as a bridge. Still a fiddly solution like an ethernet/wireless bridge as that is one more device on your LAN you have to configure tbh.
Any solution apart from the official one requires you to configure an extra device on your LAN (i.e. through web browser etc) and requires a power point (and possibly device to be left on all the time or turned on specially when you want to use 360 online).
There is no cheap/easy way to use wifi unless you are willing to leave other devices on. The MS wifi adaptor is an over-expensive add-on (I think RRP has stayed the same for 3 years!!!), people do not like to admit this, so they suggest fiddly work around solutions.
If you don't mind the hassle do it with a bridge or a router, but for the amount of money you would save and added to the fact you have to have another device plugged in, I would just but the MS one tbh. Don't think you can put a price on simplicity and ease of use (well MS think it 59.99 :) )
I see you can get these for 52.99 delivered online.
rp2000
And further to the wireless bridge, a lot of cheap Wireless Access Points can work as a bridge/client..
A large online computer component manufacturer has one for £18 that people claim works fine in 'client' mode for the 360..
Has the airport express got an ethernet port on it? If it does you can use that maybe. Not entirely sure.
I flashed an old linksys wrt54g with the DD-WRT firmware and use that. wireless signal where my xbox is isn't very good so the 2 big aerials really help
