- 14 Feb 2006
- Leeds, W Yorks.
Ok so yesterday i went out and bought a new pc case (Lian Li V600B) and got it home, the reason for this purchase is that my psu blew on my Sony Viao and the new one was a few millimetres larger and wouldnt fit back in. So anyways i transfer all my mobo and gfx cards over get everything set up and working then it comes to the 30+ little wires for the USB, Case Headphones, Mic Etc, My mobo already has these so i have not added them to the mobo as of yet, i added the other 10+ little plugs for the Power Button, Reset Switch and 2 Leds on the front, they all seem to be working fine..
So then it comes to pluggin a 4 pin power connector to my HDD and everything goes off (Seemed like something had shorted out) so i unplug everything and wait a few minutes and switch it all back on it boots up but the HDD is just silent likes it dead, tried a few other connectors that boot the CDROM up fine and still nothing, so do you reckon i have blown something in my HDD..
Also, keep in mind this is the first time i have transfered cases, i cant seem to get a Primary Master or a Secondary Master, everything i add comes up as a Slave..
Also does the way you have your round cables matter ?
And does anyone have a site that helps you out with those 1 pin plugs for the USB and other front panel things just incase i have set them up wrong ?
Thanks in advance.
Thanks in advance.
